Results 1 to 13 of 23
    Jun 2012
    Puerto Rico
    R410 Refrigerant Recovery
    I am buying a new recovery machine, which would you recommend?
    West Valley City, UT
    I picked up the Appion G1 (not the G5 twin) for under $500 this spring. It works awesome, and is small enough to fit on the van full-time without being in the way. More than enough for residential stuff.
    Jun 2012
    Puerto Rico
    I will use the equipment for light to heavy commercial use. I needa reliable equipment for every refrigerant. Thanks
    Jun 2002
    south jersey
    Appion G5 all the way. Use all the time light to heavy commercial. Fast and reliable. Not to heavy and compact. Works even quicker if you pull the valve cores. Go to appion web site to see some nice videos. Hope this helps.
    You need to put the phone down and get back to work!
    May 2011
    Oklahoma
    G5 Twin. Quit looking at others and trust us, you won't be dissapointed.
    Athens, Ohio
    Appion G5. Not too heavy, great piece of equipment.
    Jun 2012
    Puerto Rico
    Thanks!!!!
    Jul 2012
    Phoenix
    Appion for sure
    Jun 2012
    Fayetteville, NC
    Def the appion. Last company i worked for had the g5, pull the cores and it will make quick work on resi system. I have the g1 now. not quite as good as the g5 but still better than other brands and is priced very well for the quality.
    Jun 2012
    Puerto Rico
    Thanks for the advice bougth the G5 today no regrets.
    South Eastern Missouri
    Quote Originally Posted by Jborges5012 View Post
    You will love it as I do.
    A people who would exchange liberty for apparent safety, will deserve neither and lose both.
    Jun 2002
    south jersey
    Read the directions and understand your machine. It will pump liquid pretty fast in or out of the machine. Have to throttle down when pumping back in to stop from slugging. Like said before,pretty good vids out there. Congrats on your purchase.
    May 2012
    Upper Michigan
    We had to change a mini split on a roof with no outlets. It was a weird situation had an electrician there who got us outlet wired. We hooked up and shortly after saw the magic smoke and shut it down. I tested voltage on outlet and found 220. We grabbed a diff unit to finish, but a few months ago I tried the g5 and it still worked lol, just not as good. Still haven't figured out a good way to tell my boss. Must be a tough unit.
