    I just recently had a Carrier 24APA5 installed. After turning it on, I realized that there's a steady trickle of water coming out from the secondary drain into the condensate pan. Is this normal? I ran for about an hour and there was about 1" of water.
    Also, the dealer had to disassemble and reassemble the unit to fit through the attic door. In doing so, the casing for the unit isn't flush, the part where the drains attaches to the coil box juts out a bit. Is that a concern?
    Cheers,
    Dean
    manitowoc wisconsin
    It's brand new call them back.
    Take your time & do it right!
    Call before any water damage occurs.
