Results 1 to 12 of 12
    Wisconsin
    When you install a residential a/c unit and go thru a block wall with the lineset, what do you seal the hole with? I have heard that you should never let mortar come in contact with the liquid line due to corrosion.
    Any thoughts?
    Apr 2006
    super
    I have always ran the lineset in 1 1/2" conduit thru the concrete then seal with foam in the conduit
    Nov 2005
    Towns around here it's code to put a sleeve thought any cement/block wall.
    Wisconsin
    What type of sleeve do you use?
    Grottoes VA
    2" PVC sleeve and 100% silicone to seal.
    Apr 2006
    super
    1 1/2" or 2" conduit have long sweeps as well as straight pipe... sometimes you cant go straight into the wall but come at a 45 or 90... also silicone is probably better than spray foam for water seal if that is concern
    Wisconsin
    Thanks for the suggestions. I have a customer (neighbor)that has his lineset mortared in and he is concerned that it will corrode. I have never seen one get a leak when sealed in mortar, have any of you?
    Rapid City, SD
    I would think it's more likely to rub through with the slight vibration than corrode it's way though. Either way it'd be a good idea to correct it. Even if you just pry it up and fill under there with silicone that'd be better than nothing.
    For going through block (or anything for that matter) I like to use the thimbles from the thermopan guys.
    Washington
    Here is what Amick is talking about. Just scroll down the page a little, you'll see it.
    http://www.descoenergy.com/duct_system-18.htm
    Washington
    Oh, BTW I don't endorse this DIY site. Googled it ....lol.
    Apr 2006
    super
    the acid in mortor..concrete will eatup copper.
    for fix I suggest cutting a length of pipe in half and installing after carfully chippin out mortor around lineset
    manitowoc wisconsin
    To each his own.urethane is my preferrence.Dymonic by tremco is good stuff.
    Take your time & do it right!
