Thread: SEER
    Little Rock AFB
    Could someone just give me a quick briefing on SEER and SEER ratings, nothing fancy but a little help would be cool.
    Cooling efficiency for your air conditioner is indicated by its SEER (Seasonal Energy Efficiency Ratio) rating, which tells you how efficiently your unit uses electricity.
    In general, the higher the SEER rating, the less electricity your unit will use to cool your home.
    SW FL
    Question REAL SEER
    Ratings vs REALity
    http://www.advancedenergy.org/buildi...s_bulletin.pdf
    Designer Dan
