Results 1 to 7 of 7
    Woburn
    I have an Amana PTAC where the compressor is short cycling?
    the compressor comes on for about 5 min then shuts off. if you turn the unit off for a few min then back on the compressor runs again? it is a sealed system and I can't put my gauges on. Any Ideas?
    west virginia
    buy a line tap saddle type valve so u can get your guages on........youll just be guessin if u dont know them
    Woburn
    Thanx
    Thanks, I didbuy one, I just havent tried it yet. Not to keen on piercing valves.
    west virginia
    u can always put the piercing valve on and trouble shoot the system. If its worth fixing then evacuate the system and braze a couple of stem valves in there
    east central indiana
    Seen a bad thermostat make it do that.
    Stupid PTACs
    Apr 2006
    robbie
    Did you check amp on run windings...low or high??
    Woburn
    semms fine now
    The compressor was overheating and shutting down. This is a through the wall Amana PTAC. I put the valves on and the pressures seemed fine. Here's where I slap my self. I found the inside of the outer coil was blocked solid with gunk. I cleaned the coil and now the compressor stays on! Doe!
    Thanks for everyones help. I'll be comming back for more.
