Results 1 to 2 of 2
    Jul 2012
    Trane Air Handler
    I bought a home in South Carolina with a Trane Air Handler - Model 2TEC3F60A1000AA. It is only 6 years old. I need to replace the 12 year old Weatherking heat pump that it is attached to. Should I go with a Trane Heat Pump - and if so what model would be a good match with that air handler. I realize that I would also have the R22 converted to R410A.
    Also - what current model Tran air handler is that unit similar to?
    Quote Originally Posted by sspear1 View Post
    Substituting a 4 at the beginning to indicate a 410a unit.
    It is a standard blower motor air handler, so a 13 seer single speed unit would match.
    That being said it will cost you to convert the metering device to a TEV and it may be in your best interest in the long run to change the entire system and then you are not limited to the choices that you have.
