07-24-2012, 04:02 PM #1
New Guest
- Jul 2012
- 5
24x24 return boxing - joist - need a carpenter?
One of the potential contractors for our job says that if the return is large enough to require cutting a joist in the attic, then the space should be boxed by a licensed carpenter. This guy says he used to build houses for a living and understands the physical forces that a joist is responsible for resisting. He may have said something about a header or a double header.
Another contractor (who has never claimed to be a carpenter) says they cut large returns and joists all the time and boxing is a simple thing they do and it doesn't require a licensed carpenter. It sounds like he's just going to nail a piece of wood (the horizontal dashes below) for each end of the cut joist
What do you think? (sorry dont have time to line up the ascii art)
07-24-2012, 04:25 PM #2
Professional Member*
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
Ask your dealer X builder if he has ever read IRC 802.9
Openings in roof and ceiling framing shall be framed with header and trimmer joists. When the header joist span does not exceed 4 feet, the header joist may be a single member the same size as the ceiling joist or rafter.
As long as there is no roof truss involved there is no issue.
07-24-2012, 10:42 PM #3
- Dec 2010
- The Quad-Cities area (midwest).
- 1,757
Why not just put in two (smaller) returns instead of one large RA?
07-25-2012, 05:52 AM #4
