Results 14 to 17 of 17
    Jun 2006
    Richmond, VA
    Quote Originally Posted by joemach View Post
    I work for a Carrier dealer and would not want to stock or install the thermostats they sell.
    I like Honeywell better.
    I actually carry honeywells too
    But do like the edge and infinity controller.......but I am not going to carry those high dollar stats.......
    I wish I had a $1.00 for every response I deleted.....
    1. "your ductwork is too small"
    2. "your system is too big"
    3. "You Need a New contractor" Your's might be okay, but if it's not ME working on your system-your contractor must be a loser-I can see it from here.
    State College, PA
    Quote Originally Posted by beshvac View Post
    I agree!
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Apr 2009
    MA
    They would be wrong. The 800 is one of the simplest T stats to set up.
    What is the problem with yours? When did you have the system installed and what was the equipment?
    Half of the screen became unresponsive. It's 3 years old.
    Apr 2009
    MA
    I beleive they use pin bases on those thermostats, so there may not be any wiring involved, but you will need ot program it.
    Whether or not you can find a installation guide and follow how ot access the system configuration setting depends on how skilled you are with electronics. However, if you set it up incorrectly, it could damage yoru equipment.
    Do you mean program the calendar, schedules, etc. or is there more to it? I was inside the configuration settings recently trying to figure out if anything could be responsible for the screen problem I described above. It seemed pretty straight-forward.
