Results 1 to 7 of 7
Thread: Blower Service
    Blower Service
    Difficulty in removing pullys on 17 yr old Carrier RTUs nom 10TOn, 21 units at one site under contract. any tips that would assist appreciated.
    Thanks,
    GDW
    Apr 2012
    Paper Street Soap Company
    Sand paper, WD40 and a puller.
    Dec 2011
    ms
    i bought a nice pulley puller and blower wheel puller at johnstone the other day.
    Southeastern Pa
    I like the Posi Lock.
    Jun 2011
    Detroit vicinity, Michigan
    Yep, if you are trying to do this without one of these............
    Good luck.
    Home of the newly wed and the nearly dead
    Every time I do a pulley or coupling job, these same items come out of the toolbox. I throw them all in a 5 gallon bucket. In addition to these items, I've found that sometimes you just need patience.
    A rust-breaking penetrant (I like CRC screw-loose, personally)
    A lubricant like WD-40
    Some steel conduit or pipe that is just large enough to fit over the shaft.
    Sand cloth
    Scotch-brite abrasive pads
    A small mapp gas torch to heat things up a little
    A variety of pullers
    Ball peen hammer
    Spray the whole thing down with the penetrant and let it work for a few minutes. Tapping the hub lightly with hammer helps a little. If the pulley doesn't come off of the shaft easily, clean the shaft on the back of the pulley, and use the conduit or pipe to drive it onto the shaft further. Sometimes, the pulley must be heated with the torch before it will move. Once it moves just a little, it's a matter of having patience. Then, clean the entire shaft with the sand cloth, spray the hub with WD-40, and it will come right off.
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
    Jul 2012
    Phoenix
    The best lubricant I think is Kano kroil. Use that and a puller should be good. Maybe add a little heat
