Results 1 to 10 of 10
Thread: saddle valve
    NJ
    Is there a saddle valve(for refrigeration) that can grab a
    line thats 1/2" or larger?(I could use it upstream of a hold back valve on a freezer)
    May 2005
    theres one that you solder on then stick the schrader valve on using a brass cap..
    Let's give nukes a chance.
    NJ
    I don`t want to recover the freon to install a valve.
    Maine
    I believe that bullet tap-a-line valves come in 1/2", but I hate using them, they often leak after a little while. I only use them on small fractional stuff that will be tossed in a year or two.
    Tyler, TX
    http://www.supco.com/images/08vlvs&acsftngs.pdf
    Scroll down to the SF5000 series (page 8-4).
    You want an SF5512 for 1/2" OD.
    Turn off the unit.
    Braze on the saddle.
    Insert the o-ring and self-piercing core.
    Tighten the cap (this will pierce the line and lock the core in place).
    Remove the cap, and the core stays in place.
    You could use a Bullet Piercing Valve (BPV12) instead, but they tend to leak.
    I've never had a problem with the SF5000 series.
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    May 2005
    thanks wild, thats the one i was refering to..
    Mar 2006
    wisconsin
    Just wondering, are bullet valves 'legal' to leave on a system, teacher always told us its a no,no.
    Sep 2001
    East Stroudsburg, PA
    Robinair used to make one up to 3/4"OD. Rubber gasket, though...
    Tyler, TX
    Legal, but poor practice.
    NJ
    Okey I bought it today.It`s A2, for 1/2 to 5/8 inch pipe.And I think the O ring it uses is better than the one that uses gasket.Thanks for all info.
