Results 1 to 13 of 22
    Jul 2012
    Talking Walk-in-Freezer Help with compressor
    I have the job of making a walk-in-freezer work.
    The freezer was installed 3 years ago.
    it is a mishmash no name, the inly names are on the compressor and the TXV.
    The compressor is a LA50-0400-EWL-202 Coplamatic compressor. The valves have been replaced several times?? The compressor now has 1 phase shorted to ground.
    The Condensing unit is on the roof , low profile and in the sun all day.
    The evaporator is 6 feet below the condenser coil.
    There is a solenoid valve in the liquid line as the liquid line enter the wall behind the walk-in. but there is no low pressure switch anywhere to be found.
    Since I am in Thailand I can not seem to find a rebuilt compressor here, even though the factory is here in Thailand.
    Now for my question, Can I replace the existing condensing unit with a 4 ton A/C condensing Unit, an locate it with in 6 feet of the evaporator and out of the sun. The system uses R-22.
    If this will work it would save me a lot of work and money, I would of course install the proper safety and control circuits.
    I use to work and install walk-in's 40 years ago in Louisiana, but things have changed a lot.
    I would appericate any comments, advice and help with this project.
    Farang (an American in Thailand)
    Jan 2010
    A/C coil runs at 45* and a freezer coil runs at -20* to -10* there lies the problem.
    Recheck your compressor #. I do not see it in Copelands book.
    Jul 2012
    I only need to replace the Condensing Unit, I would use the old freezer coil.
    I found the compressor in the Coplamatic book, but none locally??
    May 2009
    The Pas, Manitoba Canada
    A/C condensing unit wouldn't have a suction accumulator. If there isn't one on the unit you have to replace that could take out a few valve plates and short out a compressor.
    Oct 2011
    Chicagoland Area
    Ain't gonna happen
    Jan 2010
    Quote Originally Posted by 2sac View Post
    Ain't gonna happen
    Do you show that model # as good ?
    florida
    I can't find that # either.
    Educational forums are open.
    Apr 2003
    Maple Grove, MN
    Get rid of the R22. It sucks for freezer use. Find a new R404a condensing unit designed for a walk in freezer, and a compatible TXV. Make it work like it is supposed to.
    Note... Try to blow out as much oil as you can from the evaporator and lineset as possible before you decide to switch out the txv and condensing unit to R404a.
    Jul 2000
    Guayaquil, EC
    Quote Originally Posted by crackertech View Post
    Powell had it.
    www.hvacrinfo.com/Compressors/cope_semi_asia.pdf
    florida
    Quote Originally Posted by icemeister View Post
    I should know that he has all the info by now.
    Virginia
    This question has been asked many times about using AC compressor for refrigeration , and its always a NO
    Suuuuure it would work for a short period of time ..... maybe .... but dont bother
    Oh and like said , get rid of the 22
    Virginia
    Quote Originally Posted by farang View Post
    Does it have a tin cover ?
    Most are located on the roof .... nothing odd there , but they have a tin shroud.
    Bolt a piece of plywood to the tin to keep sun off it directly. Woods a great insulator
    Hold your hand on one side of plywood , and hold a lighter under it , tell me if you feel any heat
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Snapperhead View Post
    All depends on how long you old the lighter there.
