Results 1 to 8 of 8
Thread: wtf
    Apr 2001
    MINN
    wtf
    3 comp rack med temp Oil leak on flare fitting going into oil regulator repflare. All good x 2 days. Bam same problem, change copper line and new flare nut. All good x 2 days and it happend again. Im going crazy....
    Jun 2012
    Wisconsin
    This may seem like a dumb question, but are you burring out the tubing before you make a flare?
    Nov 2010
    MN
    Using oil on flare, before and after flaring? Try a new nut.
    Nov 2005
    Three things...
    1: Too much elbow greese when tighting those flares. lol
    2: Vibration issue, which i doubt cause it would've been noticable
    3: Same flare nut used, maybe bad flare nut.
    bonus one: forgot to tighten flare nut !!! LOL when ya tired things happen.
    May 2009
    The Pas, Manitoba Canada
    Drop of loctite? Would eliminate flarenut loosening.
    Jul 2012
    Southwest
    Go buy a factory flare with an extension and nut on it already and braze in the connection.
    Apr 2010
    Richmond, Virginia
    Check for bad compressor on that rack!
    Virginia
    how long is this line ? Make a longer one and coil it in a couple of circles to absorb vibration.
