    tor rey beverage cooler
    Hello every body I need some help. I am having problem with a tor rey beverage cooler. model # r16. the unit will run until it gets about 57 degrees then it cut off as though it is in defrost. I by passed the digital controller and the compressor runs until you unplug it.
    Can anyone give me some idea on what I can do beside throw it out of the window.
    Mad customer.
    Dec 2009
    Sounds to me like you have an issue with the controller.
    Apr 2005
    Australia : Queensland
    Could be a safety , like evaporator probe holding compressor out.
    Some manufactures use this as a freeze up safety if the evap coil temp gets below say -11deg C
    More info may be of some help.
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
