Results 1 to 10 of 10
    Jul 2012
    Trane Model TWE036C140BO
    We just got from a camping trip and our ac isn't cooling at all. The unit is blowing warm air, I checked the lines to see if they were frozen. Nope, not even a bead of sweat. I checked the drain to see if it might be stopped up, its bone dry. Could this be the problem?
    Massachusetts
    A dry drain is not the problem. Check circuit breakers, reset if necessary. Make sure all switches are turned to the "ON" position, make sure the t-stat is set to "COOL" and temperature selected below room temperature. Once you've done all of those things, you've done all the homeowner should attempt. The next step is to call your HVAC contractor had invite him over to diagnose and repair the problem.
    Jul 2012
    Thanks, one more question could a bad capacitor have the same affect? The reason I ask about 6 months ago I had a service tech out for a similar problem and he had to replace a bad capacitor.
    Frederick, MD
    Anything
    Quote Originally Posted by Tony39503 View Post
    is possible, That's why you need to place a service call.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    So apparently the indoor unit is running, is the outdoor unit running?
    Jul 2012
    Yes
    Jul 2012
    Quote Originally Posted by gregp View Post
    Call already placed!
    Jul 2012
    Well it was a blown capacitor on the outside unit, Thanks for the info guys.
    Virginia
    Good old China made capacitor
    Jul 2012
    Quote Originally Posted by catmanacman View Post
    Not even close,but same difference "Hecho en Mexico".
