    Jul 2012
    Question R410a recovery and reclamation
    When evacuating empty tanks, does the r410a that is recovered have the proper mixture to be reused.
    Presumably any refrigerant that's recovered during a tank emptying process would be stored in a recovery tank containing refrigerant from several other systems. It would in that case, be unwise to try an use the refrigerant in any system due to the possiblity of cross contamination of burn out products, IMO. Others may see it differently. We don't maintain a recovery tank just for the dregs of an empty charging tank.
    State College, PA
    Does this belong in AOP or Tech-to-Tech?
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules:
    Apply for Pro Membership:
    Find your local HVAC-Talk Contractor:
Tags for this Thread
