    Apr 2012
    Best way to humidify whole house, geothermal install
    I currently have forced air propane and I'm going with Bosch geothermal. I have an aprilaire 600 humidifier on my furnace now. The plan is to move it and reinstall in the heat pump. But won't that waste a lot of water to the condensate pump?
    The water kicks on every time it calls for heat, which was fine with my oversized furnace but with the heat pump calling for heat all Winter, the water will run all the time, right? What's the best way to humidify the air in the Winter with a geo heat pump? Thanks
    Apr 2012
    Georgetown Delaware
    It should be equipped with a humidistat, set it and forget it.
    Eric
    Eric Sackett
    weberwelldrilling.com
    Delta P= 8 ATA
    www.youtube.com/weberwelldrilling
    Etters PA.
    You will find that your humidifier won't have to run as much with your geo to maintain humidity.
    Sent from my PC36100 using Tapatalk 2
    Apr 2012
    Paper Street Soap Company
    Quote Originally Posted by waterpirate View Post
    Eric
    Your average humidistat closes on humidity rise.
    Apr 2012
    Georgetown Delaware
    Quote Originally Posted by Six View Post
    Sorry I should have said " the probe thingy that senses the humidity in the house, and regulates it ".
    Eric
    Eric Sackett
    Delta P= 8 ATA
