Results 1 to 10 of 10
    Feb 2011
    OH
    server room troubles
    have a mitsubishi muya24na that when it ramps it at 70# gradualy goes to 140 sh 20 hp allway stays at 290 sc 5 amps on start up 6.7 goes as high as 7.5 out side temp 75 indoor 80 .when i first got there it was runing low .pulled disconect which then started the above .this has r410a this unit has inverter and electronic txv
    Pa
    youre saying 140 degrees super heat?
    290 degrees sub cooling?
    20 horse power?
    Nov 2007
    Mississippi
    Quote Originally Posted by HvAckid82 View Post
    20 horse power?
    I agree kid. That is about as clear as mud.
    Aug 2009
    Fort Lauderdale Fl
    I think he is saying sh is 20. High pressure is 290
    Sent from my SPH-D710 using Tapatalk
    Pa
    If he does have those readings I want to see it! What's is the highest subcooling youve ever seen? Not trying to hijack the thread.
    State College, PA
    Quote Originally Posted by david chamberla View Post
    If you have any question on charge on a ductless, pull the charge and weigh it back in. You can not diagnose a mini-split like you can a conventional system. They are not the same and do not work the same.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
    Feb 2011
    OH
    20 horse power?
    wow suction psi starts at 70 pounds than goes to140 after it ramps up supper heat 20 deg .head psi stays at 290 psi subcool 5 .is clear as mud iam old school like to abrevate spelling allways funny but work gets done . having fun yet. allways i was actually wondering if any teck has had problems with inverter or comps . would this cause those readings 'i waighed in r410 .
    Jun 2008
    I agree. The only way to know for sure if it is charged correctly is to remove the charge and weigh it.
    Feb 2011
    OH
    thank you invertor was speeding up to compensate for refrigerant waighed out charge was short waighed back in .got up and running ,went back to leack search found leak in evaperator ,its on the way only 3 y old .
    State College, PA
    Glad to see you got it figured out.
    Good job!
