Results 1 to 13 of 13
    Jul 2012
    Confused capacitors and fuses
    Help Please... I have had three capacitors in 6 months go out, two disconnect fuses blow in one week and a terminal wire burn out twice in two months. Philco 2 ton condenser. What do I get from my guy... Well they don't make capacitors like they use to. There has got to be another problem, like a loose connection or something.
    Oct 2010
    Austin, TX
    You have a serious electrical issue. If you have had a professional work on it get someone else that last guy is an idiot. If you are DIYing it, this is a no DIY site get a professional.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Jul 2012
    I plan on a new guy, just want to have an idea of what it may be. Unit replaced 6 years ago. wondering if it could be a loose connection in the disconnect or something like that. no way i'm gonna diy this puppy. thanks
    Oct 2010
    Austin, TX
    You got a dangerous electrical problem that will require either parts replaced, electrical reconfiguration, or an electric company.
    I would not expect it to be a cheap repair. You got maybe a 3% chance it will be simple cheap repair.
    Jul 2012
    one louisiana boy to another. when you say dangerous, like what? should I be Briting shicks?
    Oct 2010
    Austin, TX
    Dangerous to people who work on it and don't have the right training and gear.
    Nothings that is likely to blow up or destroy/damage property or people who aren't messing with it.
    Jul 2012
    Thanks XcelTech. I'm on the phone to the new guy.
    Oct 2010
    Austin, TX
    No Problem. What part of LA I might be able to recommend someone.
    Jul 2012
    Slidell, thanks
    Oct 2010
    Austin, TX
    Man your in my companies neck of the woods but we don't do residential. Throw an email in your profile I'll send you some mail.
    Jul 2012
    Got it
    Oct 2010
    Austin, TX
    You've got mail.
    Jan 2010
    Toronto,Ontario Canada
    The only advice that i can give you at the moment. is Call a professional (-: have a nice day. you hire cheap work you get cheap work
    Get er Done!
    Do what has to be done
    when it has to be done
    as well as it has to be done
    And doing it all the time.
