Thread: A vs N
    Jul 2012
    A vs N
    I am installing a new Carrier A/C to replace a broken ComfortMaker a/c. I am down to selcting a coil: A vs N. From the discussion above, I still don't see why I should go with one vs the other ? I can go with either but I would like a technical/engineering explanation why one or the other is better.
    Made this its own thread. You are not permitted to post in other people's threads in the AOP forums. Please read site rules, thank you.
    Virginia
    Your contractor should be picking the one best suited for the applicaton
    May 2012
    San Diego, CA
    Quote Originally Posted by mmartinez View Post
    The A-Coil is taller than the N-coil, so if you have more of a space constraint a N-Coil might be a better fit. The S-coil (Slab) is even smaller.
    The A-Coil has slightly better cooling and lower static pressure loss... so if you can fit an A-Coil then great, but the performance differences are not much so it really comes down to space constraint and cost.
    You can call me Sam
    It should be a crime to be a mechanical engineer in San Diego
    Summer Design Temperature: 83 F Dry Bulb ~ 69 F Wet Bulb (California Climate Zone 7)
