Results 14 to 18 of 18
    Jan 2012
    WEST COLUMBIA S.C.
    Clean up with shop vac.Turn a.c. off and manually pour water into drain pan and see if pan may have a leak in back of pan since pan looks dry
    May 2009
    Virginia
    A cracked pan could be causing the issue ...
    Quote Originally Posted by hewitt View Post
    You might be onto something. I never thought of a pan cracking over time but found another thread where others have had the exact same problem with a cracked pan in a WF unit.
    http://www.geoexchange.org/forum/geo...uestion-2.html
    I will try your suggestion and let you know. Thanks!
    May 2009
    Virginia
    Confused A cracked basepan is the problem
    Quote Originally Posted by virtualfreak View Post
    That was it. The basepan has cracked completely in the back right corner. I called my HVAC company for a warranty repair. The problem now is starting tomorrow the rest of the week is suppose to be 95 degrees. My cooling system is held hostage to a cheap plastic part
    Jan 2012
    WEST COLUMBIA S.C.
    Thanks for following up
    Northern Va
    well i got my * next to my name so i can post in here now. thanks for following up! did the company come out already?
