    Jul 2011
    Hmm Liquid filter dryer clotted
    What is the likely chance you changing just the liquid line filter dryer and not having the change the cap tube on a refrigeration system?
    All depends on your luck that day lol. I've cut a few inches off & it worked fine but some the only alternative was to rerun it . .
    Sent from my HTC Sensation 4G using Tapatalk 2
    Sep 2010
    Western, MO
    I've changed a lot more driers then I have cap tubes. So I would guess my chances are pretty good.
    I'm sure I'll regret that I posted this tomorrow. Looking at the clock that would be today.
    jim
    Common sense isn't very common anymore.
    Jul 2011
    I have not much luck with the cap tube system. my latest one, i had to change both. Length of the cap tube is as recommend by the manufacture and larger capacity filter dryer. not working so good. so I cut the cap tube few inches shorter than was told to get a better result.
    Apr 2002
    most of the time in the Philippines
    My experience with cap tube systems has been that if the liquid line dryer is upsized, the charge usually has to be increased to compensate. The larger drier increases the internal volume of the system. Also, I liked to angle the dryer outlet down towards the cap tube entrance.
