I need a little help understanding this. if ohms law says volts/resistance = amps then wouldn't the amps drop with lower voltage?
P = E x I
If voltage drops, current will rise to maintain Power.
E being a voltage rise.
but what happens inside the motor to cause that? is it because the reactance drops due to the slowed rotor?
Your motor has low amps or low voltage?
high amps?
