Results 14 to 17 of 17
    Jul 2012
    michigan
    My other contractor offered putting 5 ton coil on 4 ton ac unit. Does it work or is it a sales gimmick. Also what size filter would I need for 4 ton unit.
    SW Wisconsin
    Quote Originally Posted by mi2006 View Post
    With your load conditions I would stay with a 4-Ton indoor coil, the compressor will be able to pull the pressure & temp down a little better at particular loads which will be helpful for humidity control.
    IMO, the slight gain in SEER is with lab conditions &, would usually be immaterial in your conditions in Detroit.
    However, that is a decision you have to make...
    Jul 2012
    michigan
    Thank you for your advice. Is there a way to calculate by how much the heat load will be reduced if attic insulation goes from R-35 to R-60 for example. Also, should the contractors perfom manual D calculation or is it only done for new construction or remodeling
    SW FL
    Hmm Small
    876 BTU/Hr reduction based on ceiling/attic area of 1,600 square feet
    Q = U * A * dt
    120 T attic
    74 T room
    46 dT
    35 R
    0.0286 U = 1/R
    1600 A
    2102.86 BTU/Hr with R-35
    1226.66 BTU/Hr with R-60
    _876.19 Difference = 0.07 ton
    Designer Dan
