Results 1 to 13 of 18
    Sep 2011
    One can only ask customers to listen....
    So what part of "don't run the system until we come back to replace the evaporator coil" did we not explain properly? ... The homeowner put the quick disconnect back on outside and took it upon himself to run the system with low freon, and on top of that the water got into the control board and fried it costing him a lot more money than he needed to spend. when I told them the evap was frozen they said they did not run the system since i left 24 hrs ago.....
    Feb 2012
    central Florida
    Wow not suprising though.Customers always know more than the tech. How bad was it frozen when you diagnosed it.
    Afton, VA / Khorat, Thailand
    Yea, you gotta remove control wires too or inquiring minds will fool with things they aren't supposed to fool with......
    Midnight Sun Astrophotography
    Oct 2011
    Arkansas
    I take the disconnect plug-in block with me. If it's one of those ****ae Square D's that look like a breaker, I'll pull that sucker out.
    Apr 2006
    Barrie Ontario
    All you can do is recommend if they wanna run it let them just means more money in your pocket when they burn something else up.
    For some reason I learn more with my mouth shut
    Jan 2011
    You guys don't top the system off so they can use it while you source a coil?
    Oct 2011
    Arkansas
    Quote Originally Posted by jimmyed View Post
    Did that very thing last week.
    Frederick, MD
    As long
    as the customer pays for the juice. Some don't want to spend the extra $.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    Jan 2011
    We always top them off, charge for gas, source coil, pump down and charge for whatever leaked out.
    Sep 2011
    The coil was frozen when diagnosed. It was in the attic. Temp was 120f+ in there. Should have thawed out in a few hours. i never try to add freon when frozen.
    Sent from my LG-MS690 using Tapatalk 2
    Apr 2012
    Paper Street Soap Company
    it looks heavy
    May 2012
    Upper Michigan
    If you cut the sewer pipe on there toilet some of them would still **** in it and then expect you to stand in it while you fix it ha ha.
    Jul 2012
    Ashland, VA
    Quote Originally Posted by Joehvac25 View Post
    It kinda kills me a little inside how right you are.
    We were redoing some drain piping in a customer's basement ceiling and they kept running water through it, even after being reminded several times.
