Results 1 to 13 of 13
    Sep 2011
    5 ton split, fixed orifice, sweaty compressor
    My superheat is too low? I charged it with 100+ ambient at 3-5 superheat. Was i pushing it too close? Yesterday i ran the system, about 90 degree ambient and the compressor was sweating. I didnt have time to hook up the gauges, heading back today.
    (told them not to run the system)
    Quote Originally Posted by wdshea View Post
    Low load/ air flow overcharged, lots more info needed.
    Sep 2011
    Air flow is good, , indoor air temp at 81, i dont know the RH
    Nov 2005
    lots more info needed. Sub-cooling would be nice.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Sep 2011
    Why is subcooling important with a fixed orifice? B/c if it's high it means i'm overcharged?
    Furthermore, don't you need to know the SEER of the unit as well to know what the subcooling should be?
    Apr 2002
    most of the time in the Philippines
    Get yourself a charging slide rule from Trane or Carrier [or both]. I used to use them on all brands, Worked fine.
    Nov 2005
    You are answering your own questions, of course high sub cool and low super heat will tell us more then just low super heat. Ideal super heat at the compressor is between 18-22F, if you have 3-5F and your sub cooling is high, say above 10F, you may have too much gas in there. Some compressor manufacturers will even specify higher super heats, Copeland likes 35F.
    Phoenix,AZ
    I doubt a compressor around here running 35° SH would last very long before cooking the oil!
    Where do you get a gauge/meter that says air flow good?
    What was the indoor wetbulb temp when you charged it.
    Nov 2005
    Quote Originally Posted by KB Cool View Post
    you may want to check copeland's web site.
    Nov 2005
    Quote Originally Posted by allstar08 View Post
    The minimum super heat per Copeland's web site is 20F. I have attended a few classes on this and have plenty of verification. I usually run them 18-22.
    Jun 2001
    Northwest Indiana
    I have interpted the 20 superheat as a guide line to keep you out of trouble.
    It would be very difficult to maintain no lower than 20 on a fixed orifice close coupled residential split system. IMHO
    Just to clarify, was that for scrolls and recips?
    If you cant fix it right, try again.
