Thread: Weather Station
    Dec 2011
    Weather Station
    Does anyone have any recommendations for a high quality weather station to measure outside air temperature and humidity? I would like it to be compatible with either a Siemens or JCI controls system.
    1 + 1 = 3 ( *** for very large values of 1)
    ...everybody wants a box of chocolates and long stemmed rose
    Mount Airy, MD
    Should go with the JCI "FX" line, you could also use the local weather service as a back up to your onsite sensors
    Jul 2012
    Northern NY
    If you are just looking for outdoor air and humidity you don't need a weather station, just an outdoor air temp & humidity sensor that outputs the correct signal.
    I use these from Senva quite often and they work well. They also have CO2 and CO available, if you need wind speed or other condition sensors you will have to look around.
    http://www.senvainc.com/templates/pr...p?GroupGuid=19
    -Jeremy
