Thread: Gauge accuracy
    Dec 2006
    Gauge accuracy
    What is a good way to check your gauges to know they are reading correctly? I usually check them against each other to make sure they read the same against the same pressure, but how do I know if that is correct?
    Anyone have some info on a way to check them to know they are reading correctly?
    thanks
    Josh
    Dec 2006
    Goodyear, AZ
    Take a can of R-22 and set in an air conditioned office over night. Take the temperature of the tank, put your gauges on the tank and check the PT. An R-22 at 72 degrees will have a pressure of 125.5 psig at sea level. This is how I checked the refrigerant that I have recovered for non-condensable.
    Austin, TX
    zero them out then get a nitrogen regulator set it at 200 psi, connect your hose and see it if reads 200 psi.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
