Results 27 to 39 of 53
  1. #27
    Jan 2011
    No carpet here, I guess I could have some wet concrete to deal with. Attic, they get a overflow pan, but not this. On second thought, we very rarely put one in an attic. Furnaces don't belong in an attic.
  2. #28
    Aug 2008
    San Clemente, CA
    Combining the coil and fau drain without a trap and vent for the coil puts a positive pressure in the fau drain line when the blower is running. This was not designed to happen or tested by the factory. Hopefully fau drains ok.
    I always add a safety overflow switch for reasons stated.
    Nice work.
  3. #29
    Jan 2011
    The furnace drains into the same drain. Just a 1/2" cpvc fitting slid inside the 3/4" sdr21.
    Plenty of room for pressure to blow by. Plus if the drain stops up I won't have any acidic water getting to the coil.
  4. #30
    Sep 2012
    Missouri
    Nice install......really like the line set and filter drier.
  5. #31
    Oct 2005
    Phoenix, Arizona
    looks real good...Sheet metal looks clean...
    RTFM!!!
  6. #32
    Sep 2012
    Quote Originally Posted by Northfloridatech View Post
    Here in Florida near the coast you have to put the dryer inside or it won't last.
    Was told the same for here in Texas, yet most i see have it outside.
  7. #33
    Anderson SC
    looks good, nice work.
  8. #34
    Sep 2012
    NW Louisiana
    Very nice install.
    +1 on the forming of the lineset. Very clean looking.
    As for the condensate float, the inspector flagged my 1st floor unit (downdraft) for not having a coil pan float... Upstairs unit is in the attic and has a secondary float switch. Inspectors vary in what they deem code. Otherwise, AWESOME install.
    CT
  9. #35
    Apr 2010
    Naples,FL
    Quote Originally Posted by carmon View Post
    why on earth do guys install the drier inside.... it looks bad...... put it outside.. ..
    so it doesnt rust out and leak!!!! and the closer to the txv the better any crud that could be in the lines from assembly will go into the drier not the txv
  10. #36
    Rochester NY
    Quote Originally Posted by hvac wiz 79 View Post
    typically from the installs i have seen with it inside it looks like sh!t but this, i.m.o. actually looks good
    Nice looking tin too.
    These shots before you slathered it with mastic?
    Quote Originally Posted by JKopp View Post
    Hmmm...
  11. #37
    Here and there
    closer to the evap. Thats where it belongs
  12. #38
    Here and there
    Looks nice
  13. #39
    Jan 2011
    No, I don't use mastic unless it is in a crawl or attic. Furnace and both supply and return duct are in the same conditioned space. Doesn't matter.
    Quote Originally Posted by tedkidd View Post
    Hmmm...
