Page 2 of 5 FirstFirst 12345 LastLast
Results 14 to 26 of 53
    Jan 2011
    Quote Originally Posted by CoolWine View Post
    nice and clean install.
    small nitpick..steel straps on lineset.
    They are lined with foam tape
    We never do anything with the secondary drain, no one around here does. If it has a overflow pan then we put a float switch in it.
    SE Michigan
    I must be blind, because I dont see an auxiliary drain pan???
    Looks great btw!
    Jun 2012
    San Francisco Bay Area
    Great job, its nice to see someone put that extra time and effort in.
    Jan 2011
    Quote Originally Posted by coolwhip View Post
    Looks great btw!
    Why does it need one? Sink under it with a concrete floor and floor drain?
    Sep 2011
    Very nice work. Judging from the attention to detail I bet you got pressures right on the money, sh and sc to spec... I like the way the line set is just perfectly routed. I dont see anything wrong with that setup. Keep up the good work, thanks for sharing..
    Jan 2011
    I came back after the building was down to temp and it was hot out to set pressures.
    Jan 2012
    Tallahassee,Fl
    Here in Florida near the coast you have to put the dryer inside or it won't last.
    Jul 2012
    Near Chicago Il.
    Quote Originally Posted by jimmyed View Post
    I think he just meant that a couple ppl commented that you needed a float switch in a pan that isn't there that he couldn't see, and either could I.
    I never put a safety pan with a switch in either unless it was in an attic, on a rare occasion, on a first floor set up.
    NW AR
    By code we have to put a float switch in every install, wether it be in an attic or closet. It is a code I do agree with.
    Jul 2012
    ohio
    not too hateful....wierd spot though
    Fuquay Varina, N.C.
    Nice install, I would have liked to see a condensate float switch on the overflow, where is the trap for the condensate drain?
    I know that Carried recommends that the filter drier be placed by the indoor unit, I take it that other manufacturers are also doing the same. Nice clean install.
    RSES Member.
    Mainstream Engineering Certified.
    HVAC/R PM Technician.
    410A, & GREEN HVAC/R Technician.
    Indoor Air Quality Master Technician.
    NATE Core.
    Working not as to please men but to the Glory of Christ my KING.
    Jan 2011
    Trap is down low, tied it into the sink drain. EZ trap.
    We don't use overflow switches. Why all the sudden everyone pushing them with a horizontal application?
    I have only been to 1 install we did to unclog a drain. Unico system in an attic with about 40' of drain with 6" of fall over that length. Took a few years but it finally plugged. Blow it out with nitro every spring now when we change filter. Takes an extra 5 minutes.
    Fuquay Varina, N.C.
    I guess because of the amount of wet floors and ceilings I have had to deal with, especially this year, might be my location that I deal with, whenever I have a flood situation I install a float switch so I do not have to deal with wet carpets and ceilings again, though I have seen them fail too.
    RSES Member.
    NATE Core.
