Results 14 to 26 of 53
Thread: Had to hang one, on it's side.
07-19-2012, 12:42 PM #14
- Jan 2011
- 502
07-19-2012, 01:02 PM #15
I must be blind, because I dont see an auxiliary drain pan???
Looks great btw!"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
07-19-2012, 05:02 PM #16
- Jun 2012
- San Francisco Bay Area
- 54
Great job, its nice to see someone put that extra time and effort in.
07-19-2012, 06:49 PM #17
- Jan 2011
- 502
07-19-2012, 07:41 PM #18
- Sep 2011
- 59
Very nice work. Judging from the attention to detail I bet you got pressures right on the money, sh and sc to spec... I like the way the line set is just perfectly routed. I dont see anything wrong with that setup. Keep up the good work, thanks for sharing..
07-19-2012, 08:02 PM #19
- Jan 2011
- 502
I came back after the building was down to temp and it was hot out to set pressures.
07-19-2012, 11:26 PM #20
Here in Florida near the coast you have to put the dryer inside or it won't last.
07-19-2012, 11:42 PM #21
07-20-2012, 07:52 AM #22
By code we have to put a float switch in every install, wether it be in an attic or closet. It is a code I do agree with.
07-20-2012, 10:29 PM #23
- Jul 2012
- ohio
- 42
not too hateful....wierd spot though
07-22-2012, 07:44 PM #24
Professional Member*
- Mar 2008
- Fuquay Varina, N.C.
- 390
Nice install, I would have liked to see a condensate float switch on the overflow, where is the trap for the condensate drain?
I know that Carried recommends that the filter drier be placed by the indoor unit, I take it that other manufacturers are also doing the same. Nice clean install.RSES Member.
Mainstream Engineering Certified.
HVAC/R PM Technician.
410A, & GREEN HVAC/R Technician.
NATE Core.
Working not as to please men but to the Glory of Christ my KING.
07-22-2012, 10:10 PM #25
- Jan 2011
- 502
Trap is down low, tied it into the sink drain. EZ trap.
We don't use overflow switches. Why all the sudden everyone pushing them with a horizontal application?
I have only been to 1 install we did to unclog a drain. Unico system in an attic with about 40' of drain with 6" of fall over that length. Took a few years but it finally plugged. Blow it out with nitro every spring now when we change filter. Takes an extra 5 minutes.
07-22-2012, 10:53 PM #26
- Mar 2008
- 390
I guess because of the amount of wet floors and ceilings I have had to deal with, especially this year, might be my location that I deal with, whenever I have a flood situation I install a float switch so I do not have to deal with wet carpets and ceilings again, though I have seen them fail too.
RSES Member.
NATE Core.
