Page 1 of 5 12345 LastLast
Results 1 to 13 of 53
    Jan 2011
    Had to hang one, on it's side.
    First on these new furnaces I have laid horizontal. Forgot to order the grommet for the drain trap..oops.
    Around 6" of room above the false ceiling. Don't really care for the line set.
    I did go back and glue some padding on the ends of the strut!
    Mar 2006
    Float switch on the secondary drain would be nice also
    TANSTAAFL - There ain't no such thing as a free lunch!
    i like it ... nice, clean & neat
    Apr 2012
    winnipeg
    why on earth do guys install the drier inside.... it looks bad...... put it outside.. ..
    Apr 2012
    winnipeg
    i forgot to mention...... looks like great work...well done
    Quote Originally Posted by carmon View Post
    typically from the installs i have seen with it inside it looks like sh!t but this, i.m.o. actually looks good
    Feb 2011
    Cloverdale,Ca
    Look great!! Some install manuals I have read for the coils say to install the dryer on the liquid line, as close to the txv as reasonable to maximize the protection of the txv... Once again nice work..
    Living the dream !!
    Jul 2012
    Near Chicago Il.
    Nice clean install man. The sheet metal, line set and the rest looks great!
    For what it's worth, I was always taught to put the liquid drier near the coil as well. Maybe it makes no difference, who knows, I'm getting old and taught by old timers lol. for what it's worth, I don't think it hurts the look of the install.
    Nice job man!
    We put the drier in front of the meter too. It does not look bad at all.
    Gotta say a very unique install but beautifully done.
    Jan 2011
    Hadn't laid one horizontal and pulled return in the side, or the bottom now. Only thing that would work and still be able to get the water heater out of that corner.
    Drier inside. Never rusts. Closer to txv...
    nice and clean install.
    small nitpick..steel straps on lineset.
    Toronto, Ontario
    Service doors can be opened with no obstructions, Great work
    NW AR
    Very clean install. If the drier isnt internal to the unit I place them near the evaporator as well. Alot of us have started doing it.
    You need a float switch in the auxillary and/or an emergency drain pan under that coil.
