    Aug 2011
    Kansas City
    2 stage furnace 1 stage AC?
    If I get my furnace upgraded to a 2 stage unit, will it harm my 1 stage condenser? I'm just wondering with the lower (1st) stage there may not be enough airflow across the Acoil. Is it possible that it would freeze the coil before the 2nd stage was called for?
    The current AC condenser is a nordyne 2.5t R22 unit (about 15yrs old)
    Quote Originally Posted by rebelranger View Post
    No. You will have three levels of fan speed chosen by the control board.
    Highest will be cooling speed,medium will be high heat, and low will be low heat.
    Saint Joseph, MI
    No. THe furnace operation and cooling operatiosn are seperate on the furnace control board. Cooling airflows and heating airflows are seperate dip switches or taps/contactors on the control board.
    IF you go with a vairable speed blower, it's just a simple dipswitch setting.
    The most common problem is often that the blwoer speed is set too high, and.or hte ductwork is undersized or AC is oversized or a combination of the above.
    ...I guess i was a little slow to type it out.
    Aug 2011
    Kansas City
    Thanks guy, I did some more searching and find this info on here too. I forgot about the 2stage furnace being VS so the control board will ramp up and down as necessary.
    Even if it was not VS the control board would still control Y, W1,and W2 by powering 24 volts through the fan relay for the different speeds needed.
