Results 1 to 12 of 12
    Jul 2012
    Which is the best price?
    Hi everyone,
    I just got 3 offers from three different contractors, one of them had a F rating on the BBB site, so I threw it out, now the last two came at a $ difference.
    They are both to replace the inside and outside unit, since my AC is 25 years old and I'm spending WAYY too much on electricity.
    Offer 1:
    - Trane, 3.0 Unit. 16 Seer unit. Installed.
    Offer 2:
    - Pipe that drains out water will include a hose connector in case of clogs
    - Surge protector
    - Another type of protector that prevent electricity spikes every time the unit turns to save energy.
    I don't know if the extras are really worth it $ in the long run.
    Thoughts?
    Houston,Tx.
    You should delete all the pricing, no pricing "per rules".
    Jul 2012
    Sorry, thanks
    Saint Joseph, MI
    Did either one do a load calculation? The first way to save energy is to have a unit properly sized. A unit that runs continously at design conditions and above can use as much as 20-30% less energy than one that cycles on an off and will control humidity better and be quieter on the same ductwork as a older larger unit.
    If oyu've added any insulation or sealed air leaks, etc. in your home the last 25 years, you might not need as large of a unit as you have now.
    Jul 2012
    Hi,
    Yes contractor two sized the unit. I just moved in into this property, and I will need to test for air leaks. My current AC is also 3.0 ton.
    Model #s to be sure they are quoting like units?
    Quote Originally Posted by gnr5 View Post
    Hi everyone,
    Offer 1:
    Offer 2:
    - Surge protector
    Thoughts?
    Perhaps you can elaborate on accessorize items from # 2.
    Not sure how a hos connection on the condensate drain line could help.
    Another type of protector................?
    Jul 2012
    This is the quote from contractor #2.
    Thank you!
    Virginia
    That is a good setup ,i would get the 10 yr part and labor warranty Also make them provide a ahri sheet proving it is 16 seer
    Jul 2012
    So you think all the extras this contractor is offering is well worth the $ diff ?
    Virginia
    Im curios as to what a factory start up is .the work he noted should be done as part of the install
    Jul 2012
    Thats probably part of every set up
