Results 1 to 13 of 15
Thread: leaking capacitors
07-17-2012, 09:32 AM #1
- Jun 2011
- sfv california
- 80
leaking capacitors
if a run cap is leaking oil but tests within specs for mfd, do u still change it? want to get everyones opinion
07-17-2012, 10:52 AM #2
Leaking capacitors don't stop leaking once they start.
Manufacturers put a set amount of liquid/Jell inside to help cool the cap.
Heat is one of the killers of of caps, like excess voltage.
The caps days are numbered once they start leaking.
Replace it and save yourself a call back.Instead of learning the tricks of the trade, learn the trade.
07-17-2012, 01:58 PM #3
replace it run capacitor will over heat
07-17-2012, 02:12 PM #4[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
07-17-2012, 02:22 PM #5
replace it
07-17-2012, 04:06 PM #6
- Feb 2004
- New Mexico
- 4,684
If the cap is old it could contain PCB's polychlorobiphenyls. I don't remember exactly when PCB's were phased out but if old don't play with it.
Tracers work both ways.
07-17-2012, 05:28 PM #7
The ones with PCB pretty much last forever.
If its leaking, replace it
07-17-2012, 09:38 PM #8
- Sep 2008
- North carolina
- 42
I saw one today on a carrier that said it was filled with castor oil.
07-17-2012, 09:50 PM #9
Some of the gel is supposed to be biodegradable, so even if it isn't weak, it could be "rotten"?
I replace then too, since they are "bad" in the sense of leaking and they should not have the insides on the outside.Col 3:23
07-19-2012, 10:48 PM #10
- Nov 2000
- Waco, Texas, USA
- 6,153
It depends on the symptoms. If the problem was a bad contactor and the compressor run cap was leaking I would give the customer the option priced in writing. If the symptom was compressor won't always start then yes I would definitely replace the run cap.
"And remember my sentimental friend......that a heart is not judged by how much you love, but by how much you are loved by others" - Wizard of Oz.
07-19-2012, 10:57 PM #11
Isn't that what we get paid to do? Replace bad or defective parts? The customer pays us to give our professional (technical) opinion. This is a no brainer, a fluid that needs to be "IN" the capacitor is leaking "OUT". DEFINITELY REPLACE IT!
Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
07-19-2012, 11:32 PM #12
07-20-2012, 10:05 PM #13
- Jul 2012
- ohio
- 42
YES change it or it will be a callback and no one likes those....also make sure you check all wiring, amp draws, and operation just to be safe..
