Results 14 to 22 of 22
Thread: Testo 550 on sale. Worth it?
07-19-2012, 10:19 PM #14
I like my SMAN3 alot. When it had an internal leak I called Fieldpiece and they authorized an exchange for a new set at the supply house. I was back in business in an hour.
Why do some of you not like the SMAN3? Why is the Testo better?
07-20-2012, 07:27 AM #15
07-20-2012, 07:29 AM #16
Well not if you ship the broke one back and they give you a new version. That shouldn't take that long
If You Can Dodge A Wrench You Can Dodge A Ball
08-08-2012, 08:49 PM #17
I got a set of 550's in the winter and they must have been the old version. Pd 330.00 and they included some clamp for ground instead of built into the pipe clamp. After the first few normal uses the hanging hook broke, will not hold pressure when using leak test mode, pipe clamp connector pins broken and the pressures never hold steady, constantly fluctuating during use. I was excited to get them having a testo co detector that I use but I'm very disappointed with the digi's. They are nothing more than dust collectors in my truck now. I'm very careful and take care of my tools too.
08-14-2012, 12:27 PM #18
- Jul 2012
- 14
I'll take any digital over a analog anyday. To me each manufacture has its strong points. Do a side by side feature and warranty and choose which features you use most. Either way you go it will be better than analog.
08-14-2012, 09:08 PM #19
New Guest
- Aug 2012
- 2
You guys with the testo 550's do you hang the gauges in your van/truck with the clamps attached or do you put them in the case after every use?
08-14-2012, 09:42 PM #20
- Aug 2012
- Hot Springs, Arkansas
- 46
I have the sman3 and love it. It is like a GPS for troubleshooting. I guess you can get a good or bad anything these days. I still have a set of old Imperial gauges from 1986 that work like new. These digitals have a lot to live up to. I've seen a lot of folks that swear by (and sometimes at) their 550's
08-14-2012, 09:45 PM #21
- May 2010
- Canada
- 304
I put them in the case
08-14-2012, 09:54 PM #22
