Results 1 to 7 of 7
Thread: Condensor Fan Problem
07-15-2012, 04:17 PM #1
New Guest
- Jul 2012
- 2
I have a 15 yr old, 4 ton York AC in mid-atlantic. We have an extended warranty. We've only started having problems in June. I have had a service guy at my home 8 times and its going on three weeks.
Here is status:
Warranty replaced compressor (with Copeland) last week.
Capacitor, relay, and Condensing fan motor replaced over last two weeks.
Condensor fan stops after approx 15 min when AC turns on. Compressor still runs. I initially heard strain and turned off at thermostat.
This fan issue started after the new compressor was installed (week ago). Fan then replaced,days later, but also has same issue.
Service technician does not know cause. Has stood with me (twice) to watch fan stop and compressor continue after approx 15 min run time (inside house temp 80+, so never got down to comfortable range (75-78).
Only thing I noticed was that the capacitor was initially 50 amp, and was replaced with 80 amp. Technician said that should not be an issue. Thermostat is 15 years old also. Mecury. Going back into 90's this week. Technician has been here 4 times just for fan. Would like to provide guidance, if have any. He had switched contact points on capacitor (thinking that would solve, but did not).
Currently, go out every hour or so and turn on for 10+ min, then off, before compressor strains. At night, fan only. Advice?
07-15-2012, 04:24 PM #2
07-15-2012, 05:13 PM #3
Call your home warranty company and tell them you want a different service company. Cause the one they are sending out can't fix it.
07-15-2012, 05:23 PM #4
07-15-2012, 05:38 PM #5
Professional Member*
- Jul 2006
- Virginia
- 3,716
Only a moron would replace a 50 uf capacitor with a 80 uf i wonder what the other side is ,also is this a heat pump .
07-15-2012, 06:06 PM #6
I am suprised, normally home warranty companys only hire the cream of the crop.
Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
07-15-2012, 06:30 PM #7
New Guest
- Jul 2012
- 2
Not heat pump. Can't say if 50 or 80 amp or mfd/uf. Just an observer. Just know he said it was 50 and replaced with 80. I am calling for new service company. Technician nice guy, but I bet he's home in AC. Thanks for all of the input.
