Page 3 of 4 FirstFirst 1234 LastLast
Results 27 to 39 of 47
  1. #27
    Fort Worth, TX
    Seems to me if one were to take the position that 0% of HVAC contractors are capable of installing an attic fan with a concurrent understanding of its potential impact on the building envelope, this would include all HVAC contractors certified by Building Performance Institute (BPI), Comfort Institute, etc.
    No offense, but someone's paint brush might be a bit wide, here.
    Building Physics Rule #2:
    Building Physics Rule #3:
  2. #28
    Nov 2000
    Eastern PA
    Quote Originally Posted by tipsrfine View Post
    Nothing cryptic about what I said. Knowing and Doing are not the same thing.
    More vague comments. What was it that you accused me of being dishonest about? Do you even know what you are posting?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
  3. #29
    Nov 2000
    Eastern PA
    Quote Originally Posted by Shophound View Post
    This is what I was stating when I was accused of being dishonest for stating it.
  4. #30
    Sep 2009
    Arnold mo
    A percentage that starts with .00% is not equal to zero percent. 0% was robo trying to put words in my mouth. Do a google map search of HVAC contractor, and the whole USA lights up with dots on top of dots. Then do a google map search of BPI certified HVAC contractors and the dots go down to a handfull spread out across the USA. I wasn't able to count all of the dots, but it seems to back up my .00% number. Meaning maybe .009%, or something like that. My statement was the number would START out like .00%.
    An answer without a question is meaningless.
    Information without understanding is useless.
    You can lead a horse to water............
    http://www.mohomeenergyaudits.com
  5. #31
    Sep 2009
    Arnold mo
    The percentage of HVAC contractors who would know how, and perform, air sealing in conjunction with an attic fan install is likely to start out with a .00%
    What is so hard to understand about this statement? How can anyone read that to mean that I stated zero contractors know how to air seal?
  6. #32
    Nov 2000
    Eastern PA
    Call me stupid, but I still have no clue what you are trying to communicate.
    And, just an FYI; .00% is exactly the same as 0%
  7. #33
    In a boiler room
    What a lame argument..
    Worry is a really gross misuse of one's imagination. -- PHM
  8. #34
    Sep 2009
    Arnold mo
    Quote Originally Posted by RoBoTeq View Post
    You're stupid. Just kidding. Couldn't resist it. I agree that this is a stupid argument.
  9. #35
    Fort Worth, TX
    .00, without any context, would be interpreted by most as equivalent to zero. The zero to the left of the decimal point is assumed to be there, but often not expressed.
    Tips, if you wanted to make a point that less than one percent of all HVAC contractors carry building envelope certification, it would help had you made that point from the start. Otherwise, can Robo and myself honestly be blamed for mistaking your .00% to be equivalent to 0%?
    I can't help but agree this discussion has degraded into silliness.
  10. #36
    Sep 2009
    Arnold mo
    I can honestly say you & robo can be blamed for not understanding what I wrote. It has degraded into silliness, but you are adding to it.
  11. #37
    Nov 2000
    Eastern PA
    I would have thought less of you had you not taken that shot......
  12. #38
    Sep 2009
    Arnold mo
    Thanks. To be honest, I didn't like how you came into this thread with your comment that had to do with something about advice against attic fans being stupid, so I got hostile. I apologize for the implication of being dishonest.
  13. #39
    Jan 2006
    You all should check out my fb page. I do both, hvac'r and I spray foam insulation. On FB search "Solid Services LLC." Like it if you like....
    The only decision in life is to decide what to do with the time given to you
