Results 1 to 13 of 16
Thread: first post
    Jul 2012
    ontario canada
    first post
    rinnai doing double duty, dhw and 1200 sq of basement in floor in a cottage on balsam lake ontario
    i didn't put the tube in the floor, it all comes out through the sump pit in the worst possible way
    Cincinnati, Oh
    Hard for me to follow, but are you pumping into your air seperator?
    Looks good. Very good.
    "Just get it done son."
    Dad adjusted
    May 2012
    looks good but is that pipe in front of the pump it could be a pain to service if the pump fails,it might be the angle of your photo keep up the good work
    Jul 2012
    ontario canada
    thanks fellas, here's another, rinnai combi in bolton ontario, reno job .. again i didn't do the tube in the floor & the plumber hasn't hooked in on either side yet .. there's another manifold worth of tube to the left of the picture the customer didn't want to be hooked in yet, but we left provision for it later
    to answer your questions;
    mr vegas. no sir, pump away .. but i could probably have done with more horizontal lead into the air eliminator to get things more laminar .. sorry its hard to follow, camera phone
    mr 36, it's a bit picture angle and a bit tight, agreed .. in retrospect i probably should have 45'ed it out and given my self more clearance for wiggling that cartridge out
    Last edited by KlRadiant; 07-15-2012 at 08:37 AM. Reason: put the pic in as a link .. oops
    Jul 2012
    CT
    wow very nice looking very clean
    May 2012
    Upper Michigan
    Very nice, ever use ISO flanges? There not cheap but work nice.
    Jul 2012
    ontario canada
    the flanges with ball valves built in ??? yea, one of the jobs i did last month my supplier shipped them to me by accident, and i accidentally forgot to say any thing about it
    they were grundfos brand and they were very nice, beautifully made
    but they add the length of a ball valve on each side of the pump and i felt like they kinda cramped my style a bit as far as getting stuff in tight because they ate up a bunch of extra room .. i have to go back and hook in an indirect when the tilers are done in the mechanical room .. i'll make some pictures when i'm done .. i think they have a place in my tackle box, but not on every pump, too expensive
    May 2012
    Upper Michigan
    Ya those ones, I have a rule I isolate every pump, at 10 pm it saves the customers money when a pump fails.
    Jul 2012
    ontario canada
    i hear ya .. it saves a lot of time in that event trying to purge the air back out of the system
    my strategy is i try to isolate sections, and i have been using the expandable taco boxes with the module that turns the pumps on once a day during the off season
    May 2012
    Upper Michigan
    Quote Originally Posted by KlRadiant View Post
    I haven't heard of that. With the outdoor boilers I get a few pumps a year that don't start from the constant fresh water combined with sitting all summer. I will have to look into that. As far as isolation as long as there is something. My favorite is at 9 pm you get a bad pump with no valves on a 2 story house and all cast rads.
    Jul 2012
    ontario canada
    Quote Originally Posted by Joehvac25 View Post
    no valves
    that's why god invented sharkbites
    May 2012
    Upper Michigan
    Shark bites aren't that popular around here. I have only used 1 and the oldtimers frown when you say that name. I think there fine myself.
    May 2012
    Upper Michigan
    Sometimes I will try a pump with water in system, just depends on the basement and how picky the customer is.
