Results 14 to 26 of 29
Thread: Low Subcooling Low Superheat?
07-14-2012, 10:21 PM #14
Professional Member*
- May 2007
- Central NJ Area
- 628
Txv stuck open
07-15-2012, 09:37 PM #15
TXV problem
07-16-2012, 01:21 AM #16
- Jan 2012
- Fresno, ca
- 30
Read the book on that cond. Unit. I know with some Carriers, they have to be running in high capacity or you'll get funny pressure reading. Also check if the indoor blower is running in high speed.
07-16-2012, 11:40 AM #17
Sounds like more air flow is needed to me.
As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
07-16-2012, 06:07 PM #18
- Feb 2010
- IL
- 113
TXV Problem, Airflow is good at 700 CFM for a 2 ton. Newer systems call 350 CFM better dehumidification. Seems stuck open.
07-16-2012, 09:34 PM #19
- Jan 2007
- Mn the state where absolutey nothing is allowed
- 1,084
07-17-2012, 11:21 PM #20
- Oct 2009
- Florida
- 143
I believe your compressor is still in first stage. IIRC there's a five minute delay from signal sent to compressor engage in addition to the delays in some thermostats. I've seen those same pressure/temp/sh/sc conditions on a carrier two stage system that would not engage full capacity.
07-19-2012, 07:22 PM #21
- Dec 2008
- indiana
- 16
verify air flow using mini vane or equev.
what is the amp draw at compresor
is the evap coil / blower clean
what is return wb and
supply wb
how did you figure capacity
07-20-2012, 01:41 AM #22
- Dec 2011
- British Columbia, Canada
- 51
have you tried testing the txv by heating and cooling the bulb?
07-20-2012, 06:32 PM #23
- Jan 2007
- 1,084
its been 6 days, the OP hasnt been back, guess he fix it.?!?
so we can all benefit, it'd be nice to here how these threads end upmy boss thinks its possible to repeal the laws of physics
07-29-2012, 04:40 PM #24
- Jan 2011
- Maryland
- 9
Fixed
Sorry for the delaying in posting, While I was on vacation, another tech replaced the indoor coil. After replacement the system ran at spec's 12 deg s/c 9 deg of s/h. althought the coil would frost evenly when the blower was off. We ran out of options and replaced the coil. I am requesting an RMA back to Carrier to have the coil tested. If I get anything back I'll post thier finding.
Thanks all
07-29-2012, 08:47 PM #25
- Nov 2011
- USA
- 184
07-29-2012, 09:46 PM #26
- Jan 2011
- Maryland
- 9
tXV
The TXV was changed from the factory Danfoss to a Sporland, The equalize line was check for flow. All checked good. Air flow was double checked by checking pressure drop a crossed the coil. .58wc
