    Unhappy
    Hi,all I have slight problem.installed a new goodman system and while hooking up indoor unit I lost the high side nut. it slid down the line and under the cement slab my supply house is trying to locate.is there a part number or a parts breakdown available anywhere.thanks in advance mike
    Florida
    Did you try chasing the LL with a shop-vac with a hose or piece of tube? Might get it out.
    Aug 2005
    call East Coast Metals in Mcdonough Georgia. They always have damaged equipment. I am sure they will give you one of a damaged air handler are coil. ask for Tracey!
    Smile
    thanks all for your replys supply house found it and its on the way.mike
