Results 1 to 13 of 20
    Jun 2012
    Northern NJ
    mini-split indoor units
    Greetings.
    One of my customers would like to install air conditioning. They have hydronic heat and the house is relatively small. I thought that a mini-split would be ideal. The problem is that most indoor units are 35 to 45 inches wide and I just don't have a home for this. Does anyone know of an indoor unit that is about 24 inches wide. I would be installing this in a free standing closet and blowing the conditioned air out the top into a great room. I probably could install a conventional system, however, because the closet is in the living space, I am concerned about the sound level. Suggestions would be appreciated. Thanks
    Austin, TX
    I can't think of a single model that is only 24" wide.
    Jul 2012
    central VA
    Maybe a window unit
    I rather do nothing and be happy than to do something and not be happy
    Dec 2006
    Litchfield,Il
    There has to be a place somewhere on an exterior wall. If you have that many windows your in trouble.
    If your not getting the results you desire then change. People change from either desperation or inspiration.
    Jun 2012
    Great lakes
    I know I installed a mini split that was a ceiling mount, can't really rember the name brand tho. But they are out their
    May 2012
    San Diego, CA
    I couldn't find one for Mitsubishi but LG has wall frames and ceiling mounted ones... I am sure all the other manufacturers do too...
    http://www.lg.com/ca_en/air-conditio...tial/index.jsp
    You can call me Sam
    It should be a crime to be a mechanical engineer in San Diego
    Summer Design Temperature: 83 F Dry Bulb ~ 69 F Wet Bulb (California Climate Zone 7)
    Jul 2012
    central VA
    Mitsubishi makes a flush ceiling mount air handler unit
    We did a 3 head Mitsu system a few months ago. Due to no place to put a wall unit, one room got a floor mount. Rather pricey but what we had to do.
    Is there an attic?
    If so, some of the mini split manufacturers make ducted air handlers.
    Jun 2012
    The Woodlands, Texas
    I did a lot of HVAC work while I was in the US Army and most of it was with European and Asian mini split systems.
    All of the big brands (Mitsu - Fujitsu - LG) would offer you two options.
    A small air handler type unit, that would fit in an attic or a crawlspace, and feed ductwork.
    There is also what is called a ceiling recessed unit, that mounts flush with the ceiling.
    Tony
    Jun 2012
    Northern NJ
    The room to be conditioned is a great room with a cathedral ceiling ... no attic. The only exterior wall has a fireplace and a pair of windows ... no space for an indoor unit. The other 3 walls are either covered with furnishings or are archways to other rooms. This is the reason that I chose to put a unit in a closet that separates the great room from another part of house. This closet is 24" deep on the interior and about 40" wide; the 24" side is adjcent to great room. I had cosidered putting a ducted evaporator in the closet, but they all seem to be 35 to 42 " wide ... thus it will not fit. I also considered using one of the ceiling mounted units that are about 24" square. To do this I would have to mount it upside down on top of the free standing closet. I understand that this will not work because drainpan will not catch condensate. Further, these units will not handle the 2 ton that I think we need.
    At this point, I think the closet will get a conventional air handler that takes air in at the bottom of the closet and blows it out the top toward the top of the cathedral ceiling. I am concerned with noise levels as the closet is only about 7' high which means the blower will be close to the supply and return to the living space. I'm considering a 2 stage compressor so it can run at a low speed most of the time an only run high when necessary. I have not found documentation concerning what controls the speed.
    Is it possible to run a mini-split compressor with an conventional air handler? I don't know what kind of control signals are available to get these 2 units to work together and to modulate speed when necessary. Further, I don' know if any manufacturer woud warranty such a configuration.
    I appreciate \your thoughts and thanks for comments to date.
    Jun 2011
    New Mexico
    Mitsubishi makes a 2-ton vertical air handler that is 18" wide and 21" deep. It would connect with a 3-ton condensing unit. It is from their City Multi line, which allows multiple evaporators with a single condenser.
    http://usa.mylinkdrive.com/uploads/d..._Submittal.pdf
    Mar 2010
    Kent, WA.
    fujitsu makes a unit called slim duct. im sure mitsu and the other ductless manufacturers make similar system. they are designed for minimal ductwork like in a wall with a low return and high discharge. or in a sofit where somebody might want some nice linear diffusers.
