Results 14 to 21 of 21
Thread: A-coils Upside Down
07-14-2012, 04:32 AM #14
The indoor evaporator coils is cold on all parts of the coil, so no matter which way the air runs through them, they should cool the air.
Now the refrigerant travels through the coils in the same direction so certain set-ups will give slightly better cooling, but the manufacturer knows best and everything should be installed per the instruction manual.
Also, how do you put an extra drain pan on a downflow system without blocking the duct if the coil is installed upside down?You can call me Sam
It should be a crime to be a mechanical engineer in San Diego
Summer Design Temperature: 83 F Dry Bulb ~ 69 F Wet Bulb (California Climate Zone 7)
07-14-2012, 04:34 AM #15
I've seen an inverted A coil. I don't remember the brand. It had a small plastic drip pan under it, factory stuff all the way. No reason it shouldn't work. It's no different in principle than a diagonal slab coil except that there's two of them at opposite angles butted together sharing a single drip pan. I'm still wondering though, if what you saw was actually an Air Seal Assembly, which resembles a pan but isn't. It's there to prevent condensate blow-off, and is removed on downflow applications. A downflow kit is required for that application. The kit contains a flat sheet metal plate that replaces the Air Seal Assembly.
07-14-2012, 05:02 AM #16
- Jul 2012
- Chicago
- 63
The extra drain pan was much smaller than the other one. Not sure exactly how it was mounted. Do you find it impossible to believe that once upon a time there was a coil designed to work both downflow and upflow, but where Carrier expected you to flip it to use in the downflow configuration? I think that I will try to contact the owner that explained that to me and review the details with him. BTW, when we tried to use it in the downflow configuration without flipping it, with it's normal drain pan on the bottom, water blew or got sucked around the pan and into the duct. That makes sense if it wasn't intended to work that way.
07-14-2012, 05:16 AM #17
The coil your mention might not be a "multipoise" coil... I wonder how Carrier fixed the water being blown into the ducts problem with the new multipoise coils.
You can call me Sam
07-14-2012, 05:33 AM #18
- Jul 2012
- Chicago
- 63
07-14-2012, 05:40 AM #19
What is the model number of the coil?
07-14-2012, 05:46 AM #20
- Jul 2012
- Chicago
- 63
Thank you. I thought I was losing my mind there for a minute. I hate to not know what I'm talking about.
I think I know what you mean because I think I just saw a picture of it. I can't find it again. I was looking for proof of what I was talking about. I didn't find that, but I saw a shallow pan looking thing with sloped edges on top of an old coil. Mine was an actual pan with right angle sides, and an attachment for a hose, and we used it as a fully functioning pan after a few mods to keep water from blowing around it.I'm still wondering though, if what you saw was actually an Air Seal Assembly, which resembles a pan but isn't. It's there to prevent condensate blow-off, and is removed on downflow applications. A downflow kit is required for that application. The kit contains a flat sheet metal plate that replaces the Air Seal Assembly.
07-15-2012, 12:13 AM #21
