Results 1 to 13 of 17
    I'm seeing a lot of notes about the influence of relative humidity on comfort and some where the poster now has a new system that isn't doing as well as the old one - but has no information on what the relative humidity was earlier.
    Any reasonably accurate 'humidometers' ( ) available at a reasonable price?
    Thanks!
    Florida (some where) way-south
    Walmart or HomeDepot
    doing one call at a time.
    Madison, WI/Cape Coral, FL
    Also Radio Shack. Really like the digital hygrometers. 15-30 dollars. Wal-Mart/Radio Shack have indoor outdoor with several radio remote transmitter. <50 dollars. TB
    Nov 2005
    Northern VA
    How is the response time on those Radio Shack models? I have a cheapo Walmart model right now, and it takes several minutes for the reading to stabilize. Doesn't work very well for walking around checking the temperature/humidity in various parts of the house. Getting several, and hoping the calibration doesn't drift too far out, is one option. I'd like to have one GOOD unit to go around and check with though, if that's practical.
    Staten Island NY
    Humidity
    I had the same concerns: price and response time. I finally chose to buy a Bacharach sling psychrometer for about $60 from Grainger. I paid more than I wanted, but I will never have to calibrate it, and it is portable.
    I have two of the radio shack units and I'm skeptical of both. One checked out okay with the salt paste test, the other 10 points too high. The one that checked out okay reads 44% now, which seems low.
    Huntsville,AL
    reptile shop @ $10 -- put in baggie of salt water -- should read 75% overnight --
    4H: Hot, Humid Houston H.O.
    The salt water test is fine as far as it goes, but it tests accuracy at one RH when you might want/need to know accuracy at a much lower one in your house. At least I *hope* you don't have 75% RH in your house!
    I have a half dozen cheap humidity meters, most from Walmart. One day with nothing else to do I put them all in the same place and recorded each reading after they had 20-30 minutes to stabilize. Repeated for 8 different readings as high and as low as could find, in the 40-70% range. Although it might have been of some value to know the temperature at each condition, at the time I did not suspect this and so did not record that.
    What I planned was to assume that the errors on the high side of correct %RH were random and equal to the errors on the low side. With that assumption one could average the readings and get pretty close to the objective, correct answer. My result was a set of calibration tables where I had a good estimate of error at 8 points along the RH scale.
    The surprise was that being accurate at one RH, did little to promise accuracy at the others. The error curve appeared to be random, in most cases was within 3% or 4%, with an outlier or two at 5% error measured on the RH scale.
    It seems the sensors in my thermostats and dehumidifiers are similarly imprecise. That matters little when you design to control RH over a +/- 5% band, which seems to be the norm. Not like temperature measurement, where we usually expect spot-on accuracy.
    So while I don't promise too great accuracy with these cheap little devices, I sure do like their ease of use. For real accuracy though I defer to the sling psychrometer, anyone traditional enough to use that earns my respect!
    Hope this helps -- Pstu
    Warren, MI
    Re: Humidity
    Hmmm, I started a "digital hygrometer response time" thread here, hardly got a hit!
    Even a high priced handheld digital hygrometer will take 15-20 minutes to adjust to a 5F change in temperature! If temperature is constant, humidity response is real fast!
    A sling psychrometer is much faster from what I hear.
    Can you even calibrate it? How accurate is the temperature?
    I returned a Fluke 971 which they deemed faulty to be replaced with a new one, tossed in calibration for free! It's just as slow as the old one but I find out now that's the way all handheld digital hygrometers are! Well, at least it's calibrated now.
    Bill
    SW FL
    Thumbs up Hygrometer +
    Oregon Scientific has seemed to be quite reliable,
    But do NOT look for a fast response.
    http://www.oregoninstruments.com/pro...p?itmky=256466
    Check outdoor thermometer section at Lowe's
    for $24.
    Designer Dan
    Panama City Beach, FL
    I found an interesting link on hygrometer calibration that includes a list of salts and the RH that they achieve in a closed environment. You could work out a complete calibration curve from 6 to 97% and work out all that randomness!
    http://www.kingofthehouse.com/hygrometer/
    Potassium carbonate gives a 43% environment. It's used in soaps and wine making and is available on ebay for very cheap. Any wine-making stores nearby? I have a 10 percentage point error between my thermostat RH reading and my Extech reading, so I'm looking forward to doing this.
    Huntsville,AL
    the old Honeywell T87 round t-stat had 5/9F accuracy --
    probably the indicator is not accurate -- just the actuator of a t-stat is = what I want to work best --
    so, the RH% gage is off 5% --
    not much different than relying on the weatherman"s temp reading 5+ miles away & over a mountain -- which shifts our winds such that we do not agree with the weather station ~ 2miles away at "exec" airport --
    but, we are on a mountain, in woods -- 3- 10F cooler in summer!
    I'm fortunate to have a friend two blocks away that has his weather station hooked up to wunderground.com.
    To clarify, I don't mean a 10% difference, 40% vs 44%, I'd be fine with that, I mean a 10 point difference, 40% vs 50%. And worse, I put a new battery in the Extech and now it's a 13 point difference. If the Extech is accurate, then I could be looking at at mid to high 50's RH.
