Results 1 to 12 of 12
Thread: bad compressor?
    Jun 2007
    bad compressor?
    hey guys whats up? had a breaker keep tripping when condenser unit would kick on so i tested the compressor ohms from lead to lead got a beep, ground to leads got no beep windings should be good correct? i then disconneted the wires from compressor pushed in contactor fan spins no triped breaker hooked compressor back up push in contacor trips breaker.this is a single phase 60hz 208/230v compressor it is a york unit also changed contactor and dual capacitor.please help its hot lol thanks in advance.
    SW Wisconsin
    You have to have a megohm-meter to test for grounded windings.
    That is also not the way we ohm check the windings...
    Call a contractor with Techs that have the proper test instruments.
    There could also be bad capacitors & bad wiring connections, etc.
    Marty AC, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Further infractions may result in loss of posting privileges.
    Frederick, MD
    Are you
    planning to replace the compressor yourself? I would call a pro to check it. Depending on age, you may want to replace the system.
    GO NAVY, BEAT ARMY!
    A DECADE OF DOMINANCE! +3
    Virginia
    Sounds bad to me windings are shorted just not shorted to ground,now go onloine order a compressor, buy a recovery machine, torch ,vacuum pump get your epa card and all the other incidentals and get r done,and if you mess it up order another compressor and try again
    Jun 2007
    Have all that thanks!!
    Jun 2007
    Uda you funny not!!
    Virginia
    SW Wisconsin
    Tell us the entire sequential procedure that U are going to follow when U replace the compressor, &/or the condensing unit...
    If U don't do it right U'll have problems sooner than U want...
    Jun 2007
    Uda wow "Sequential Procedure"Such big words you must be very smart. I'm just a blue colar boy so use words like steps,next etc.....
    Jun 2007
    Thanks gregp i will look into a new unit as well it is over 17 years old.
    Jun 2007
    Quote Originally Posted by catmanacman View Post
    Lol
