Results 1 to 10 of 10
    florida
    how can you tell what the seer rating is if you dont have the paper work?
    ACHEATMAN
    model #s.
    florida
    seer
    where at in the model #s
    ACHEATMAN
    you gotta scratch 'um off to see if you won
    or look for help from the manufacturer,or ari, or prestons maybe...somewhere there are lists of such information
    Apr 2004
    Lol
    You need to know the model numbers of the outdoor unit, the indoor coil and the indoor air mover. Even then, you may not know because not every possible combination has beeen rated.
    Of course this is a factory rating, installation and applications play a big part in determining how efficeint a system is.
    Jul 2003
    Los Angeles, California
    You could figure out the SEER rating of the condensing unit using the tonnage and the rated amps.
    Jul 2003
    But than you would have to find the nameplate.... which has the model number on it.
    SW FL
    Thumbs up
    ... which will give you a calculated EER.
    Designer Dan
    South Dakota
    The rated SEER and the installed SEER may not even be close.
    Houston,Tx.
    This is getting scary but I agree with Norm, this has to be the second or third time this year must be the new fish oil vitamin I started taking, keep my brain swimming.
