Page 10 of 11 FirstFirst ... 34567891011 LastLast
Results 118 to 130 of 134
Thread: Fieldpiece
  1. #118
    Jan 2013
    North Carolina
    The SC77. The sheer jump in quality and trust in my meter has been significant. Next fieldpiece purchase will likely be a set of SMAN3 or SMAN4 manifolds. Probably in a few months
  2. #119
    Feb 2013
    Fairhope,AL
    Still got my 8 year old SC66...works every time.
  3. #120
    Atlanta GA area
    I have been using a SC76 for over a decade... just found the DC volts does not seem to work well anymore. Would not have known other than checking a battery... never use DC volts.
    I have an SC77 for a backup... rarely use it. One of these days the 76 will die and the 77 will become the main meter.
    GA-HVAC-Tech
  4. #121
    Oct 2008
    Fullerton
    This is my personal favorite
    http://www.youtube.com/watch?v=q71dN...y9qcEcS_lXdSyA
  5. #122
    NTexas
    Besides the price, what is the difference between the SC56 and the SC55?
    edit: The video explains the difference at the very end. I think I'm going to go with the 56 even though it's a bit more in price. I like the inrush current feature.
  6. #123
    May 2002
    Orlando,FL
    I have a question concerning the SMAN3. On my third one due to the high side malfunctioning. Any truth to what I have been told about nitrogen causing issues with the sensor(s) ? I have heard about others having the same issue.
  7. #124
    Inert gas causing issues........ Never heard that one
  8. #125
    Feb 2013
    New Orleans, LA
    Quote Originally Posted by marybear View Post
    I always flush my SMAN3 with nitrogen after each use, and have never had any problems with the sensors! I know a few people with SMAN's and most of them flush with nitrogen after each use and never have had problems. Maybe check your Nitrogen regulator or maybe the hose for some type of contamination?! Just trying to help out if I can.
    Good Luck
  9. #126
    Atlanta GA area
    I know I am throwing gasoline on the fire... sometimes it is fun...
    My DC is 7+ years old... I have ABUSED the sensors to death (hit with pressures over 500#, pulled vacuums through the manifold then hit with release of refrigerant, sensors have never been cleaned, never flushed the manifold)... not a single issue with them.
    GA-HVAC-Tech
  10. #127
    Jan 2013
    What was the name of that brand ....? ....Diggi Spew?
    (ga-hvac-tech, it's also amusing to throw in a rejoinder..)
  11. #128
    Tallahassee, FL
    Yeah that's exactly what I want to do......flush the manifold each time? Nope.
  12. #129
    Atlanta GA area
    Quote Originally Posted by hvac5646 View Post
    Yeah, it just keeps spewing out ACCURATE readings day after day after day after day after day... All I have to do is change the battery 3-4 times a year.
    GA-HVAC-Tech
  13. #130
    Jan 2013
    1spew
    verb \ˈspyü\
    Definition of SPEW
    intransitive verb
    1
    : vomit
    2
    : to come forth in a flood or gush
    3
    : to ooze out as if under pressure : exude
    transitive verb
    1
    : vomit
    2
    : to send or cast forth with vigor or violence or in great quantity <a volcano spewing out ash> —often used with out
    — spew·er noun
    See spew defined for English-language learners »
    See spew defined for kids »
    Examples of SPEW
    Exhaust spewed out of the car.
