Page 9 of 11 FirstFirst ... 234567891011 LastLast
Results 105 to 117 of 134
Thread: Fieldpiece
  1. #105
    Jan 2013
    North Carolina
    Tomorrow is the day I purchase. Still havent fully decided, but my old craftsman meter is no longer trustworthy. When you get readings of 300A on a blower motor that has a rating of 4A, you know your meter is toasted
  2. #106
    Quote Originally Posted by northstarair View Post
    FP hs36, I love this meter and trust it with my life daily.
  3. #107
    Jan 2013
    North Carolina
    I'm leaning towards the 77.
  4. #108
    May 2010
    Canada
    I prefer the SC56 over the SC77. The swivel clamp make life easier.
  5. #109
    Jul 2005
    Quote Originally Posted by eddiegoodfellar View Post
    I found out the other day that the temperature function on my SC56 doesn't work. I loved that meter until I discovered this, now I'm not so sure about the build quality. I typically toss a meter in the dumpster if one of the functions quits or gets out of whack because I no longer feel that I can trust the remaining functions either. If anyone wants it I'll take 100 bucks for it. I accept paypal.
  6. #110
    Jul 2005
  7. #111
    May 2010
    Canada
    Quote Originally Posted by hvacrmedic View Post
    I found out the other day that the temperature function on my SC56 doesn't work. I loved that meter until I discovered this, now I'm not so sure about the build quality. I typically toss a meter in the dumpster if one of the functions quits or gets out of whack because I no longer feel that I can trust the remaining functions either. If anyone wants it I'll take 100 bucks for it. I got it shortly after they were released, so it's definitly used and has some cosmetic wear, but it isn't beat up either. I accept paypal, and will post some high res pics upon request.
    What doesn't work on it? Is the range off or does it not read at all?
  8. #112
    Jul 2005
    It doesn't read at all. Sometimes it'll flash 32 degrees for a second before blanking out. On second thought, I had better check out all of the functions before selling it to anyone. I haven't used all of the functions recently, I mainly use amps, ac volts, ohms, and capacitance. I should probably test them all for accuracy using my Fluke 289.
  9. #113
    Dec 2009
    maroon lazyboy
    might be a loose connection in your thermocouple
  10. #114
    Jul 2005
    Quote Originally Posted by knave View Post
    Naw, it isn't that. I tried several different t-couples and even took the back off the meter. Nothing was loose. I tried the calibration screw and could get it to read for a few seconds with it turned all the way to one of the stops, but it would still blank out and then of course wasn't registering the correct temperature either, so I gave up on it. It's just broken. A also installed a new battery but that didn't help either.
  11. #115
    Other than when I was checking out all the features when I first unboxed it, I've never actually used the temperature function of my SC56.
  12. #116
    Jan 2013
    It doesn't read at a . I should probably test them all for accuracy using my Fluke 289.
    Fluke 289..USA made... I could not agree more. And at $500 a pop it says quite a bit about the quality of tools the buyer owns.
  13. #117
    Do you try to short it out if it will read a cold junction. Not sure if it works like that on this meter.
