Results 1 to 10 of 10
    SE Pennsylvania
    Tried to Google this with no luck. Can any of you Trane guys help me out? Air handler model number TWE030C140b0.
    I know its 2.5 ton variable speed. Need to know if it has electric heat and approximate age. The guy says its about two years old however it appears they started making this version on '98. Any other facts would be appreciated. Thanks
    Jul 2002
    It should have a manufactured date on the data plate if not a serial number is needed. The heater is located behind the top door if in upflow configuration.
    It is not variable speed. Usually there is a mfrd date on the name plate, if not the serial # will tell. Post it. Trane air handlers do not come with heat, it would have been added in the field so can't tell you that.
    SE Pennsylvania
    I thought the TWE was variable speed...as on Trane's web site..or was this the first year for TWE and variable speed?
    Rapid City, SD
    Originally posted by ocbythebay
    TWE030C140b0.
    TW - split component heat pump compatable
    E - Electric furnace (like they said, heat strips are added in the field, could be anything from 10kw to 25 kw)
    0 - Brazed refrigeration connection
    30 is 2.5 ton like you mentioned
    C - Major development sequence C is standard system, E would be VS motor, P would be high eff system
    1 - 220-230/1/60 (electric rating)
    4 - Accurtron flow control check valve
    0 - Standard insulation
    B - Minor design sequence (means nothing other than to the facotory)
    0 - Service digit (they change these as they do "improvements" on thier stuff)
    SE Pennsylvania
    Thanks guys.. I appreciate it
    Jun 2006
    Good description on previous post, but not entirely correct:
    TW 'E' = convertible, vertical or horizontal setup
    TWV, you guessed it vertical
    TWH, horizontal
    Where the 'B' is located, in Florida they use an 'F' because units are insulated differently. Typical example; TWE040E13FB0, variable speed, convertible unit
    Apr 2009
    NC
    Confused OMG. I forgot how to read model number!!
    I had forgot how to read model number. How could he tells from TWE030C140b0.
    Quote Originally Posted by amickracing View Post
    Would you guys tell me where I could start read on this information.
    Jul 2009
    Plant City, Florida
    Quote Originally Posted by ocbythebay View Post
    The model number will not tell you the age, it should be on the tag.
    The age can be determined by the serial number.
    If it is installed with ductboard, look at the date on the tape, if they used fresh tape, that is one indication of age.
    Jul 2010
    can anyone tell me what each part of this model number is? ysc120e4emb000 it is a trane
