    Jun 2007
    Pigeon Forge, TN
    what gas does this walk in take from pressures
    Found and fixes leak. Can anyone tell me what gas this walk in Cooler takes from these pressures?
    Condenser fan cut in 200 diff. 35
    Compressor cut in 28 diff. 20
    High pressure cut out 350
    There is also a temperature control in the walk in.
    The more you know, the more you realize how much you don't know.
    Jun 2007
    Pigeon Forge, TN
    Never mind. Found 134a sticker on evaporator
    Sep 2010
    Western, MO
    If the tag was hard to find, I hope the last guy put 134a in it.
    If you didn't swing by and write it or add a sticker to the compressor.
    jim
    Common sense isn't very common anymore.
    Nov 2003
    It it's 134a, that HPC needs to be at least 100# lower and the CFM cut in lower
    Aug 2009
    Peoria IL
    Quote Originally Posted by smilies View Post
    i agree double check all your setting there they are off for 134a
    Jun 2007
    Pigeon Forge, TN
    Thanks for all the input. Got it going.
