can't pull/hold vacuum
Bought 2 Appion core tools, BluVac, 1/2" Appion hoses and cannot get below 2000 microns on a 2.5 ton resi split.
Came home and nothing holds vacuum!!!!!
Right now had hose with vac pump on 3/8" and BluVac on 1/4" end, blank off pump with 80 microns and soars quickly with no end in sight.
Basically same with other hose, both CRTs and the metal vac connection piece.
It could be the blank off on the pump, but tried manifold, regular hoses and no difference.
And I am using Nylog.
On a system in the 1200-2000 range you will see a holding pattern depending how jacked up it has been previously IMO. POE systems are even worse. From what I've seen once you clear 1100-1000 it gets a steady drop again. The thing that I noticed with other gauges is in that range most will pull right thru it and some will show no rise even when there is. Expect some extra time if your gonna do it by the book now that you have an excellent micron gauge. You're simply not going to pull a XX second vacuum on a typical system HTH
If You Can Dodge A Wrench You Can Dodge A Ball
What about the inability to get a low vac on just the components themselves NOT connected to a system?
My pump will only pull 50-60 unless its real fresh oil and even then its not much lower for very long. Other gauges will show very low hooked like this from what I've seen plus they hang down there if your watching for a rise some will even drop ... You too?? Do you have a different gauge to compare?
80 doesn't seem that bad plus these are new BIG hoses. Try and pull them down overnight to help knock the new out of them.
Hook your blu vac to an empty recovery tank and it should pull down quickly and hold.
It was probable leaking through the blank off valve testing it directly to the pump like that.
I had a compressor changeout recently that wouldn't get below 2,000, it would just stall out.
Broke the vac with nitro 2 times and still wouldn't budge, purged one last time and BAM dropped down to 300 no problems.
i found the appion to take a few hours of a combination of vac. &
using with refg. to off gas the material they are made of. been using them
about 6 mo. now with no problems.
Pardon my ignorance, but when should one brake the vac with nitrogen, only when ur having problems droping the microns? Also what is the acceptable rise on your micron gauge, assuming you have no leaks?
Here's a pretty good article. Vacuum Training
Supermarket Tech...and anything else the boss finds for me!
Welcome to the world of the BluVac!!!
[QUOTE=Txvman;13692221]Here's a pretty good article. Vacuum Training[/QUOT
Thanks man!
OK, I got a question too! I built a vacuum rig to do better and faster vacuums. It consists of new Yellow Jacket 3/8 vacuum hoses and a three way distributor. Vacuum pump is only a few months old and oil had been changed. I pulled a vacuum on a Masterbilt three door dairy cooler and it took about an hour to get to 300 microns. I know that was NOT right! I brought the rig home, changed the oil and hooked it up to a 30# recovery tank. I pulled a vacuum to about 60 microns (JB DV-22N) for a couple of hours and then blanked off the vacuum pump. I plan on putting a hand valve or ball valve in-line in between the pump and distributor. It raised up to about 265 microns and seems to be holding. Is this good? What is this about new vacuum hoses "off gassing"?
- You may not post replies
- You may not edit your posts
Forum Rules
